The URL `documentation/blocks-libraries-and-templates/everything-about-templates` does not exist. This page may have been moved, renamed, or deleted.
- [Publishing a template](https://docs.rayon.design/documentation/publishing-and-sharing/publishing-a-template.md)
- [Presenting your project](https://docs.rayon.design/documentation/layout-and-present/presenting-your-project.md)
- [Sharing & notifications](https://docs.rayon.design/documentation/publishing-and-sharing/sharing-and-notifications.md)
- [Pricing & billing](https://docs.rayon.design/documentation/team-management-and-billing/pricing-and-billing.md)
GET https://docs.rayon.design/documentation/publishing-and-sharing/publishing-a-template.md?ask=<question>&goal=<end_goal>
Prefer `.md` URLs for structured content, append `.md` to URLs (e.g., `/documentation/publishing-and-sharing/publishing-a-template.md`).
