The URL `documentation/blocks-libraries-and-templates/what-are-blocks-and-libraries` does not exist. This page may have been moved, renamed, or deleted.
- [Sharing & notifications](https://docs.rayon.design/documentation/publishing-and-sharing/sharing-and-notifications.md)
- [Pricing & billing](https://docs.rayon.design/documentation/team-management-and-billing/pricing-and-billing.md)
- [Custom properties](https://docs.rayon.design/documentation/layout-and-present/custom-properties.md)
- [Measurement: distance & area](https://docs.rayon.design/documentation/design/measurement-distance-and-area.md)
GET https://docs.rayon.design/documentation/publishing-and-sharing/publishing-a-library.md?ask=<question>&goal=<end_goal>
Prefer `.md` URLs for structured content, append `.md` to URLs (e.g., `/documentation/publishing-and-sharing/publishing-a-library.md`).
