The URL `documentation/import-export-and-sharing/everything-about-sharing` does not exist. This page may have been moved, renamed, or deleted.
- [Exporting & printing](https://docs.rayon.design/documentation/import-export/exporting-and-printing.md)
- [Publishing & sharing](https://docs.rayon.design/documentation/publishing-and-sharing.md)
- [Publishing a template](https://docs.rayon.design/documentation/publishing-and-sharing/publishing-a-template.md)
- [Pricing & billing](https://docs.rayon.design/documentation/team-management-and-pricing/pricing-and-billing.md)
Perform an HTTP GET request on the following URL with the `ask` and `goal` query parameters:
GET https://docs.rayon.design/documentation/import-export/exporting-and-printing.md?ask=<question>&goal=<user_goal>
`goal` is what the user is ultimately trying to achieve, the reason they need the answer. Sharing it helps GitBook give you a better, more relevant answer. A goal is most helpful when it describes the outcome the user wants rather than restating the question. For example, with `ask=how do I create an API token`, a goal like `automate deployments from our CI pipeline` lets GitBook tailor the answer to that use case.
Prefer `.md` URLs for structured content, append `.md` to URLs (e.g., `/documentation/import-export/exporting-and-printing.md`).
