> For the complete documentation index, see [llms.txt](https://docs.rayon.design/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.rayon.design/documentation/import-export/exporting-and-printing.md).
# Exporting & printing
As DWG, DXF, PDF, or images
You may **export your model** as **PNG, PDF, DWG, DXF** or **simply send it to your printer.**
### Exporting an image <a href="#h_327a882dca" id="h_327a882dca"></a>
To **export** your **model** as an **image**:
* Open the **`Pages`** panel.
* Then, click the **`+`** button to **create a new page.**
* **Select the page frame** on the canvas and resize it to fit your drawing.
* Select **`... > Export > PNG`** in the **Page panel**.
* That's it! Your file is saved in your **Downloads folder.**
{% embed url="<https://player.vimeo.com/video/1136827390?autoplay=1&controls=0&loop=1&muted=1>" %}
Alternatively, you can export the whole screen as an image through **`Menu > Export > Image`**.
To get more **tips** about **pages**, go to the [Pages documentation](/documentation/layout-and-present/pages.md).
<figure><img src="https://2112124689-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FngVHKyaUSSJPTFck3wkz%2Fuploads%2FsIfr4TOXtNnXWfH1DYGM%2FPreviewer.png?alt=media&#x26;token=5c63a567-b098-4b42-9512-7db700bce36d" alt=""><figcaption></figcaption></figure>
### Exporting a PDF file <a href="#h_e7382427ae" id="h_e7382427ae"></a>
To **export** your **model** as a **PDF file**:
* (Optional) Set your **page** **scale** in the right panel.
* Select **`... > Export > PDF`** in the **Page panel**.
{% embed url="<https://player.vimeo.com/video/1136833630?autoplay=1&controls=0&loop=1&muted=1>" %}
### **Exporting a DWG or DXF** <a href="#h_e7382427ae" id="h_e7382427ae"></a>
To **export** your **model** as a **DWG** or **DXF file**:
* Click on the **`Menu`** button.
* Hover over **`Export`** and choose **`DWG`** or **`DXF`**.
* Click on the **`Download`** button that appears on top of the editor.
*Note: When exporting to DWG, the colors of the entities will be based on the color of the layer they are placed on. More about our* [*layers*](/documentation/design/layers.md)*.*
{% embed url="<https://player.vimeo.com/video/1136837266?autoplay=1&controls=0&loop=1&muted=1>" %}
{% hint style="info" %}
**Exported file looks empty?** Your model might contain stray elements far from the main drawing. Delete them before exporting. More in our FAQ.
{% endhint %}
## **Printing** <a href="#h_e7382427ae" id="h_e7382427ae"></a>
To **print** your **pages** and send them to your printer:
* Then, click the **`export`** button.
* In the export modal that opens, select the **`print`** option.
* The browser print interface will show up.
* Choose your paper format and printer and press **`print`**.
{% embed url="<https://player.vimeo.com/video/1136838566?autoplay=1&controls=0&loop=1&muted=1>" %}
More about [our support policy right here](/other-resources/others/support-policy.md).
