> For the complete documentation index, see [llms.txt](https://docs.rayon.design/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.rayon.design/documentation/layout-and-present/presenting-your-project.md).
# Presenting your project
Show your pages on screen, or send them to your client as one link.
**A presentation is a set of pages you show on screen or send to your client as one link.** Every model has **`All pages`**, which holds every page, and you can make your own. They're all in the dropdown at the top of the **`Pages`** panel.
<figure><img src="https://2112124689-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FngVHKyaUSSJPTFck3wkz%2Fuploads%2FYlcInB7Yfp9eyByQs8Ls%2Fpresentations-in-the-pages-panel.png?alt=media" alt="The Pages panel with the presentation dropdown open: All pages, Client set and Create presentation…"><figcaption></figcaption></figure>
### Show your pages on screen
In the **`Pages`** panel, press **`Preview presentation`** (the play button), or `ALT` + `P`. It plays the presentation picked in the dropdown, with your pages as they are now. In the preview, use:
* `F` to toggle full screen
* The arrow keys to move between pages
* `ESC` or **`Back to model`** to leave the preview
* **`Publish`**, in the bar, to open the Publish window. Once the presentation is published, the bar has **`Copy link`**, **`Open presentation`** and **`Publish changes`**, which publishes without opening the window.
### Make and edit a presentation
* **Make one.** In the dropdown, choose **`Create presentation…`**. Or press **`Create`** (the +) at the top of the **`Pages`** panel and choose **`Presentation`**. Every page starts ticked or, if you had pages selected, only those. Untick what doesn't belong, name it, and press **`Create`**. To pick by number, switch **`Pages`** to **`Selection`** and type a range like `1, 3-4`.
* **Change its pages.** Pick it in the dropdown, press **`Edit presentation`** next to it, tick or untick pages, and press **`Done`**. Or right-click a page and tick or untick a presentation under **`Add to presentation`**.
* **`All pages` has no edit button.** It always holds every page.
With a presentation picked, the panel lists only its pages, numbered in its order. On the canvas, the other pages' names turn gray. A page you create while it's picked joins it.
<figure><img src="https://2112124689-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FngVHKyaUSSJPTFck3wkz%2Fuploads%2FAcubIxz6zxNOp6SIWdpk%2Fediting-a-presentation.png?alt=media" alt="Client set picked in the Pages panel, Edit presentation next to it; on the canvas, the page outside the presentation is grayed"><figcaption></figcaption></figure>
### Send a presentation as a link
Pick the presentation in the dropdown and press **`Publish`** below it. Check the pages in the window and press **`Publish`** again. The link appears once you publish: press **`Copy link`** next to it and send it.
<figure><img src="https://2112124689-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FngVHKyaUSSJPTFck3wkz%2Fuploads%2Fe0NmzCkW9EEZYGOtMUwd%2Fpublish-before-and-after.png?alt=media" alt="The Publish presentation window before publishing (not published: Cancel and Publish, no link) and after (published: the link with Copy link and Open presentation, and Publish changes)"><figcaption></figcaption></figure>
A presentation with a live link is marked **`Published`** in the dropdown. A second play button sits next to **`Share`**. Its menu lists your presentations and marks a published one too.
In the **`AI`** panel, the agent can build a presentation for you, on new pages it makes. The link at the end of its reply, **`Publish`** followed by the presentation's name, opens this same window. More about it on the [Make a presentation deck](https://docs.rayon.design/documentation/work-with-ai/ai-use-cases/make-a-presentation-deck.md) page.
### Keep the link up to date
Publishing works like issuing a set of drawings. Your client gets your pages as they were when you published, and keeps that set while you carry on working. To issue your latest work, press **`Publish`**, then **`Publish changes`** in the window. Your client sees it as a new version on the same link, the next time they open it. Rayon doesn't tell them. Right after you publish, the button reads **`Published`**. When you reload or open the window again, it reads **`Publish changes`** even with no edits, so it does not tell you whether the link is out of date.
* The window shows your pages as they are now, which is what **`Publish changes`** sends. To see what your client has, press **`Open presentation`** next to the link.
* **`Last updated`** is when you last published, not when you last edited.
{% embed url="<https://player.vimeo.com/video/1246533754?autoplay=1&controls=0&loop=1&muted=1>" %}
### What your client sees
Your client opens the link in any browser, with no account. Along the bottom of the screen they have:
* **`Fullscreen`** (`F`)
* **`Leave a comment`**, to pin a comment on the page
* **`Measure distance`** and **`Measure area`**
* **`Show pages`** (`P`), and arrows to move between pages
* **`Download as PDF`**, which saves the version on screen. Until the PDF is ready, a spinner takes its place.
* **`Copy link`**, to pass your link on
<figure><img src="https://2112124689-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FngVHKyaUSSJPTFck3wkz%2Fuploads%2FbCi6YUDcr6nUJZjN4wZz%2Fpresenting-client-bar.png?alt=media" alt="The bar at the bottom of your client&#x27;s screen: Fullscreen, Leave a comment, Measure distance, Measure area, Show pages, Download as PDF and Copy link"><figcaption></figcaption></figure>
On a phone, the bar has a **`More`** menu with **`Enter fullscreen`**, **`Show pages`**, **`Show comments`**, **`Download as PDF`**, **`Copy link`** and **`Measure`**.
### Versions
Your first publish is Version 1, each **`Publish changes`** adds the next, and the link always opens the newest.
* Your client sees the version number and date in the corner.
* To go back, they press **`Show pages`** (`P`) and pick a version from the dropdown at the top of the panel. The newest is marked **`Latest`**.
* A client with the link open has to reload to see a new version. If they picked a version, reloading keeps it, so they need to open your link again.
<figure><img src="https://2112124689-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FngVHKyaUSSJPTFck3wkz%2Fuploads%2FU9xjZ9nSHltvIPFTMVef%2Fpresenting-versions.png?alt=media" alt=""><figcaption></figcaption></figure>
### Comments
Anyone with the link can read and add comments. You have no switch to turn them off on a presentation.
* **Add a comment.** Your client presses **`Leave a comment`** and clicks on the page to place a pin. A client who is not signed in to Rayon adds a name first. Then they write and press **`Comment`**.
* **Draw on the page.** Before pressing **`Comment`**, they press **`Annotate`**, draw, and press **`Done`**.
* **Reply or resolve.** They click a pin or a drawing to open the comment, then reply or press **`Resolve`**.
* **See them all.** **`Comments`**, on the left of their screen, lists them by page.
{% embed url="<https://player.vimeo.com/video/1246533759?autoplay=1&controls=0&loop=1&muted=1>" %}
You read the same comments in the **`Comments`** panel of your model, where comments from a client who is not signed in are marked **`Visitor`**. A signed-in client comments under their own name.
<figure><img src="https://2112124689-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FngVHKyaUSSJPTFck3wkz%2Fuploads%2FmX9UUFf681esgYNfScn5%2Fpresenting-comments.png?alt=media" alt="A pin and its open comment on your client&#x27;s link, beside the Comments panel of your model where the same comment is marked Visitor"><figcaption></figcaption></figure>
You can reply, resolve or delete them there.
* Comments stay on the link across versions, so a pin left on Version 1 also shows on Version 2.
* A resolved comment leaves the list. To see it again, press **`Filter`** and tick **`Show resolved comments`**.
* Comments don't show in full screen. On a phone, **`Show comments`** in the **`More`** menu opens them.
### Unpublish or delete
* **`Unpublish`**, in the Publish window or in **`Edit presentation`**, takes the link down for anyone who opens or reloads it. Publish again and the same link comes back, with its earlier versions.
* **`Delete presentation`**, in **`Edit presentation`**, takes the link down for good and deletes its versions. Your pages stay on the canvas.
### Good to know
* **The Share link is a different link.** The link from **`Share`** > **`Access`** > **`Public link`** opens the model itself. Presentation links keep working whether that switch is on or off.
* **Page numbers follow the presentation.** While the **`Pages`** panel is open, numbers placed with **`Page number`**, in a title block for example, follow the picked presentation's order and show 0 on pages outside it. Pick **`All pages`** to number every page again. When you leave the panel, the numbers and the gray names go back to **`All pages`**. When you open it again, your pick returns. More about page order and numbering on the [Pages](https://docs.rayon.design/documentation/layout-and-present/pages.md) page.
* **Names.** A link to **`All pages`** shows your model's name in your client's browser tab and on the PDF file. A link to any other presentation shows that presentation's name. The preview card of a link in a chat or an email always shows the presentation's name, so a link to **`All pages`** reads "All pages" there.
* **Older links.** If you published a presentation before you could make several, it's now **`All pages`**, and its link keeps working.
