> For the complete documentation index, see [llms.txt](https://docs.rayon.design/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.rayon.design/documentation/import-export/exporting-and-printing.md).
# Exporting & printing
As DWG, DXF, PDF, or images
You may **export your model** as **PNG, PDF, DWG, DXF** or **simply send it to your printer.**
### Exporting an image <a href="#h_327a882dca" id="h_327a882dca"></a>
To **export** your **model** as an **image**:
* With your model canvas open, click the **`+`** next to the **`Layers`** header and choose **`Page`** to **create a new page** over your drawing.
* **Select the page frame** on the canvas and resize it to fit your drawing. On a model canvas, resizing the frame changes the page scale, not its paper size.
* Open the **`Pages`** panel.
* Select **`... > Export > PNG`** on the page's row in the **`Pages`** panel.
* In the **`Export pages`** modal that opens, choose a **`Quality`** and click **`Export`**.
* That's it! Your browser asks where to save the file, or saves it in your **Downloads folder.**
Alternatively, select **`Menu > Export > Image`**, then **`All`** or a single page.
An image always comes from a page. To export the whole screen, use a PDF, DWG or DXF export instead, as explained below.
Pages cannot be created on a 3D canvas, so switch to a model or paper canvas first.
To get more **tips** about **pages**, go to the [Pages documentation](https://docs.rayon.design/documentation/layout-and-present/pages.md).
### Exporting a PDF file <a href="#h_e7382427ae" id="h_e7382427ae"></a>
To **export** your **model** as a **PDF file**:
* (Optional) Set your **page** **scale** in the properties panel. On a paper canvas, the scale stays at 1:1.
* Select **`... > Export > PDF`** on the page's row in the **`Pages`** panel.
* In the **`Export pages`** modal that opens, set your options and click **`Export`**.
<figure><img src="https://2112124689-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FngVHKyaUSSJPTFck3wkz%2Fuploads%2FLH63gEjbr9cLd6IRWXtt%2Fexporting-pages-modal.png?alt=media" alt="The Export pages modal, with a page preview on the left and the Name, Format, Pages, Image quality and More options settings on the right, above the Portfolio, Print and Export buttons."><figcaption></figcaption></figure>
To export what is on your screen, select **`Menu > Export > PDF > Export screen`**. This saves a PDF right away, with no page and no modal.
### Export options
The **`Export pages`** modal opens for every page export and every print. You can also open it with **`CMD/CTRL`** + **`P`**.
* **`Name`**: the name of your file.
* **`Format`**: **`PDF`** or **`PNG`**.
* **`Pages`**: **`All`**, or **`Selection`** with a **`Range`** like 1-3, 5, 7. This row shows when the modal opens with more than one page.
* **`Image quality`**: for a PDF, **`High (300dpi)`**, **`Medium (200dpi)`** or **`Low (100dpi)`**.
* **`Quality`**: for a PNG, **`Low`**, **`Medium`** or **`High`**.
* **`Remember options`**: keeps these settings, except **`Pages`**, for your next export of this model.
Under **`More options`**:
* **`Use page stroke scale`**: sets how strokes print. More in our [Pages documentation](https://docs.rayon.design/documentation/layout-and-present/pages.md).
* **`Finer detail level`**: keeps exact coordinates in a PDF instead of rounding them. The file gets larger.
* **`Export hatches as vector patterns`**: writes hatches in a PDF as patterns, when the hatch pattern allows it.
* **`Export each page as a separate PDF`**: shows when you export two pages or more.
The **`Portfolio`** button shows for a PDF and needs more than one page. It uploads your PDF and opens it in our portfolio viewer, in a new tab. More about [Portfolio](https://docs.rayon.design/other-resources/apps/portfolio.md).
### Exporting several pages
To export several pages at once, use any of these:
* In the **`Pages`** panel, select your pages and click the **`Export selected pages`** button (the download icon). With nothing selected, the same button reads **`Export pages`** and exports every page the panel lists.
* With pages on several canvases, open a canvas section's **`...`** menu in the **`Pages`** panel and choose **`Export pages`**.
* Select **`Menu > Export > PDF`**, then **`All pages`** or one of your **`Presentations`**.
* In the **`Canvases`** section of the **`Layers`** panel, right-click a canvas that holds pages and choose **`Export`**, then **`PDF`** or **`PNG`**.
Several PNGs, or separate PDFs, arrive as a zip file.
When a presentation is active in the **`Pages`** panel, the panel's export covers its pages only.
### **Exporting a DWG or DXF** <a href="#h_e7382427ae" id="h_e7382427ae"></a>
To **export** your **canvas** as a **DWG** or **DXF file**:
* Click on the **`Menu`** button.
* Hover over **`Export`**, then over **`DWG`** or **`DXF`**.
* Choose **`Screen`**, **`Selection`** or **`Canvas`**.
* In the **`Export to DWG`** or **`Export to DXF`** dialog, click **`Export`**.
* Click on the **`Download`** button that appears on top of the editor.
* That's it! Your file is saved in your **Downloads folder.**
{% embed url="<https://player.vimeo.com/video/1246533716?autoplay=1&controls=0&loop=1&muted=1>" %}
<figure><img src="https://2112124689-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FngVHKyaUSSJPTFck3wkz%2Fuploads%2FU2noWalVUqaMlfnyu1Fy%2Fexporting-dwg-menu.png?alt=media" alt="The main menu open at Export, listing Image, PDF, DWG, DXF and Rayon file, with the DWG submenu showing Screen, Selection and Canvas."><figcaption></figcaption></figure>
* **`Screen`**: what is visible on your screen.
* **`Selection`**: the elements you selected. It stays gray with nothing selected.
* **`Canvas`**: the whole active canvas.
The file holds the active canvas only. Pages on other canvases do not come along.
DWG and DXF carry 2D content only.
In the dialog, **`Pages`** exports your pages as layouts. Under **`More options`**:
* **`Fills and hatches`**: creates entities for fills and hatches.
* **`Images`**: creates a zip file with your images. It is on by default, so expect a zip file when your canvas holds images.
* **`Textures`**: creates an entity for each tile, when **`Images`** is on.
* **`Fonts`**: creates a zip file with your fonts.
* **`Standalone views`**: exports views that are not on a page.
* **`Use ACI colors only`**: converts colors to the AutoCAD Color Index.
*Note: When exporting to DWG, the colors of the entities will be based on the color of the layer they are placed on. More about our* [*layers*](https://docs.rayon.design/documentation/design/layers.md)*.*
{% hint style="info" %}
**Exported file looks empty?** Your model might contain stray elements far from the main drawing. Delete them before exporting.
{% endhint %}
### Exporting a Rayon file
To save a copy of your model as a RY file, select **`Menu > Export > Rayon file`**. The file is saved in your **Downloads folder.**
More about [importing a RY file here](https://docs.rayon.design/documentation/import-export/pdf-and-image-import.md).
### **Printing** <a href="#h_e7382427ae" id="h_e7382427ae"></a>
To **print** your **pages** and send them to your printer:
* Then, click the **`Export pages`** button (the download icon), or press **`CMD/CTRL`** + **`P`**.
* In the **`Export pages`** modal that opens, click **`Print`**, or press **`SHIFT`** + **`ENTER`**.
* The browser print interface will show up.
* Choose your paper format and printer and press **`Print`**.
