The URL `documentation/publishing-and-sharing/presenting-your-project` does not exist. This page may have been moved, renamed, or deleted.
- [Presenting your project](https://docs.rayon.design/documentation/layout-and-present/presenting-your-project.md)
- [Publishing a template](https://docs.rayon.design/documentation/publishing-and-sharing/publishing-a-template.md)
- [Publishing & sharing](https://docs.rayon.design/documentation/publishing-and-sharing.md)
- [Sharing a model or a workspace](https://docs.rayon.design/documentation/publishing-and-sharing/sharing-a-model-or-a-workspace.md)
GET https://docs.rayon.design/documentation/layout-and-present/presenting-your-project.md?ask=<question>&goal=<end_goal>
Prefer `.md` URLs for structured content, append `.md` to URLs (e.g., `/documentation/layout-and-present/presenting-your-project.md`).
