Publishing a library
Create your own libraries to share blocks and styles with your teammates!
In Rayon, both blocks and styles can be curated and published, to help you maintain consistent standards across drawings. On this page, we go over the steps needed to create libraries.
Publishing a block library
A block library is a model containing a collection of blocks that you can curate and share with other users. Let's dive in and see how to create such a library!
Start from a model where you have blocks you want to share.
In the
Blockpanel, click on thePublishbutton in the panel's header.
Once clicked, the publication modal should appear. There, you can choose the blocks you want to share, before hitting the Publish button in the footer of the modal. Once published, your blocks become available to you and other users from any model in your current team.
Publishing a style library
Similarly, a style library is a model containing a collection of styles that you can curate and share with other users. Let's dive in and see how to create such a library!
Start from a model where you have styles you want to share.
In the
Stylepanel, click on thePublishbutton in the panel's header.
Once clicked, the publication modal should appear. There, you can choose the styles you want to share, before hitting the Publish button in the footer of the modal. Once published, your styles become available to you and other users from any model in your current team.
We are always available
Book a demo with our team, right here. To get some support, reach out to us through our in-app support chat. More about our support policy right here.
