For the complete documentation index, see llms.txt. This page is also available as Markdown.
Navigation & command access
Moving around in a model and calling commands.
Before we start drawing, let's quickly review how to navigate and access commands in Rayon.
Navigating in Rayon is easy. It can be set from the editor context menu, or from the user settings.
All you need to do is choose a Navigation mode, either Mouse or Trackpad.
If you are using an Apple Magic Mouse, you should enable the Trackpad mode as it will allow you to swipe to pan.
Mouse mode
  • To Zoom, simply scroll.
  • To Pan, hold your mouse wheel down and move.
Trackpad mode
  • To Zoom, pinch on your trackpad.
  • To Pan, swipe with two fingers.
Command access
Command access can be set from the editor context menu, or from the user settings.
It can be set to either shortcut mode or command line mode. Either mode's shortcuts can be found here.
Shortcuts mode
  • Lets you trigger a command using single- or double-key shortcuts, with no validation keystroke.
  • You may open the command line with CMD/CTRL + K.
Command line mode
  • Lets you trigger a command using single- or double-key shortcuts, and a validation keystroke (Space or Enter).
  • Type anytime on your keyboard to search for a command.
Next step
You are done! Head to the next step, click below!
Next step
We are always available
Book a demo with our team, right here. To get some support, reach out to us through our in-app support chat. More about our support policy right here.
