For the complete documentation index, see llms.txt. This page is also available as Markdown.
The AI toolbox
Discover Rayon AI in a few simple workflows.
We explain here how Rayon’s AI feature set can be used, to what end, and showcase a few well-known workflows.
Where to find AI in Rayon?
First and foremost, AI can be found in our toolbar, in the AI tools section.
Additionally, AI tools can be found when selecting an image, in the selection bar.
Finally, an AI chat can be found in the AI panel. Talk to it to learn how Rayon works. You can also ask specific questions about your model.
What to do with Rayon AI?
Get help/Find content
Get tips and best practices on how Rayon can be used. The panel will offer you some detailed advice, visuals, tutorials, etc., to help you get around the software.
Get help — The AI panel is the go-to place to find useful advice about Rayon and its feature set, and to be redirected to useful resources (tutorials, docs, etc.).
Find content — Alternatively, let the AI panel help you find blocks, styles, and templates from Rayon’s repositories, and get quick access to all of our resources.
Generate/edit images
All tools can also be found and used inside our AI panel. We detail here each workflow, performed inside the AI panel.
Edit images — This command will allow you to edit an image with a prompt, or target a specific area of that image to edit. Alternatively, this command will enable you to create a new image from scratch.
Remove background — The Remove background command will subtract any background scene from an image, and replace it with a transparent fill.
Generate axonometry — Submitting a screenshot of a floor plan to the Generate axonometry command will create a 3D axonometric view of that scene.
Expand image — Rayon allows you to expand an existing image. With or without a guiding prompt, the Expand command will recreate an image in continuity with the image you submit.
Generate CAD drawings and blocks
Rayon can also generate geometry, either by tracing an existing image, or by generating CAD blocks from a text prompt or an image of a product.
AI tracing — Rayon allows you to generate the CAD tracing of an existing image. Rayon will simplify the scene/drawing, apply a wireframe style to it, and generate the 2D tracing of that image.
AI product generation — Rayon allows you to generate the 3 views of a CAD block, starting from a text prompt or the image of a product.
Generate floor plan
Rayon can also generate a vector-based floor plan, using walls, openings and zones, starting from a simple image of a floor plan, or even a drawing of one.
Generate videos
Rayon can generate videos directly onto the canvas, where they play in place. Use them to make your presentations richer, more dynamic and more engaging. Videos can also be imported onto the canvas.
Jobs
At any point, AI jobs can be found in the Jobs tab of the AI panel. A job can be deleted or rerun from there.
We are always available
Book a demo with our team, right here. To get some support, reach out to us through our in-app support chat. More about our support policy right here.
