> For the complete documentation index, see [llms.txt](https://docs.rayon.design/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.rayon.design/documentation/work-with-ai/use-rayon-in-claude.md).
# Use Rayon in Claude
Connect Rayon to Claude to work on your Rayon models in conversation. Claude can find your models, explain drawings, edit them and create presentations. Results open in a Rayon viewer inside the conversation.
## Connect
You need a Rayon account.
1. In Claude, open **Settings → Connectors**.
2. Find **Rayon** and select **Connect**.
3. Sign in to Rayon and approve access.
## Example prompts
* "List my Rayon models."
* "Open the model I worked on last and explain its floor plan."
* "Suggest two alternative sofas for the living room. Do not change anything yet."
* "Replace the sofas with the first alternative and show me the updated plan."
* "Create a client presentation of the updated plan."
## Troubleshooting
| Problem                     | What to do        |
| Sign-in fails.              | Disconnect Rayon in **Settings → Connectors**, connect again and sign in with your Rayon account. |
| Claude cannot find a model. | Check that the model is in your account or shared with you.                                       |
| An edit is refused.         | You need edit access to the model. Ask its owner to change your role.                             |
## Support
Contact us through the in-app chat or see the [support policy](https://docs.rayon.design/other-resources/others/support-policy).
