> For the complete documentation index, see [llms.txt](https://docs.rayon.design/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.rayon.design/documentation/layout-and-present/custom-properties.md). Agents can also search and read this documentation through its [MCP server](https://docs.rayon.design/~gitbook/mcp).
# Custom properties
Assign and list properties of your items.
On this page, we cover **how to use, create and manage custom properties in Rayon.**
### What is a custom property?
Offering **custom properties** is Rayon's way of **allowing users to add data to their drawing**. This information can be added onto **`models`**, **`zones`**, **`walls`**, **`blocks`** (instances and definitions), **`shapes`**, **`layers`**, **`styles`**, and **`pages`**, and later be **retrieved, listed, and formatted in tables.**
In Rayon's editor, **custom properties can be found in the `Custom properties` section** of the properties panel. With nothing selected, the section shows the **`Model properties`**. The section stays hidden for a selection that cannot carry properties, such as a canvas table.
<figure><img src="https://2112124689-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FngVHKyaUSSJPTFck3wkz%2Fuploads%2FclFlhvCo3sGXFEQBpiPW%2Fcustom-properties-section.png?alt=media" alt="A selected block instance with the Custom properties section open in the properties panel."><figcaption></figcaption></figure>
### Creating a custom property
Let's start by **creating a new custom property.**\
With an entity selected, find the heading that names your selection in the **`Custom properties`** section, such as **`Instance properties`**. Click on the four-dot icon next to it, with the tooltip **`Select properties`**. Then, click on the **`+`** button in the header of the popover, with the tooltip **`Add new property`**. This will allow you to **create a new property** that will be applied to the current selection.
<figure><img src="https://2112124689-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FngVHKyaUSSJPTFck3wkz%2Fuploads%2FsbQmudL3jHgh0VUuJsvw%2Fcustom-properties-select-popover.png?alt=media" alt="The Select properties popover open beside the properties panel, with a list of properties and their checkboxes."><figcaption></figcaption></figure>
You will now have to specify the **`Name`**, **`Type`**, **`Format`** and **`Value`** of the new property you are about to create. The property **`Type`** expresses the kind of thing the property documents (a price, a name, a length, etc.). In Rayon, available types are:
* Text
* Length (in model units)
* Area (in model units)
* Volume (in model units)
* Number
* Price (in the model's currency)
* Link
* Yes/No
* Image
* Linear cost (a price per unit of length)
* Surface cost (a price per unit of area)
The **`Format`**, then, allows you to choose whether the property should be a...
* Value (a single value)
* Single select or Multi select (a list of values, for Text only)
* Formula (a value computed dynamically, based on other properties, for Number, Length, Area, Volume and Price only)
Yes/No, Image, Link, Linear cost and Surface cost have no **`Format`** row, because they always hold a single value. In a Price formula, multiply a Linear cost by Length, or a Surface cost by Area, to get a total.
Clicking on **`Save`** will confirm the creation of the property and apply it to the selected entities. **`Type`** and **`Format`** cannot change after a property is created.
<figure><img src="https://2112124689-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FngVHKyaUSSJPTFck3wkz%2Fuploads%2F5RMDhVnfZicSnLJyfDN8%2Fcp-add-property-dialog.png?alt=media" alt=""><figcaption></figcaption></figure>
You can also create a property from the **`Add column`** dropdown of a table. More about it in [tables](https://docs.rayon.design/documentation/layout-and-present/tables.md).
### Applying custom properties
Any existing custom property present in the **`Select properties`** popover can be **applied to the selection** by simply ticking its checkbox. A property inherited from a definition or a style cannot be unticked: its checkbox is disabled.
### Managing custom properties
At any point, custom properties present in a model can be managed from the left side of the screen. The **`Custom properties`** panel stores all existing properties added by you or other users at any point, whether or not they are applied to the current selection. From there, custom properties can be...
* Searched
* Created (from the **`+`** button, with the tooltip **`Create property`**)
* Renamed (**`Rename`** in the three-dot menu of a property)
* Edited (**`Edit`** in the same menu, for the name, plus the list of values or the formula)
* Deleted (**`Delete`** in the same menu)
A property created from this panel has no value yet. Apply it to a selection to give it one.
Properties created by table templates show in purple in this panel. They cannot be renamed, edited or deleted.
<figure><img src="https://2112124689-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FngVHKyaUSSJPTFck3wkz%2Fuploads%2FsZtZOUgPQ0us52MlAqAS%2Fcustom-properties-panel.png?alt=media" alt="The Custom properties panel with its list of properties, a three-dot menu open, and the Create property form."><figcaption></figcaption></figure>
### Inheritance
Another useful feature of custom properties is **inheritance**. In other words, the custom properties carried at one level can be transmitted to a lower level. For instance:
* **`Definition`** → **`Instance`**: A property carried by a block definition will also be carried by its instances.
* **`Style`** → **`Entity`**: A property carried by a style will also be carried by entities carrying that style.
At any point, an inherited property can be overridden; for instance, the value of a property inherited by an instance from its definition can be changed to a different, specific value. The value can then be set back to its initial value by clicking on the reset icon next to the property name.
