Publishing a library (blocks, styles)
Create your own libraries to share blocks across models or with your teammates!
Publishing a block library
A blocks library is a model containing a collection of blocks that you can curate and open to other users. Let's dive in and see how to create such a library!
Start from a model where you have blocks you want to share.
Click on the
Share
button, in the top-right of the editor.Select the
Libraries
tab and togglePublish blocks
on.
Now, open any other model located in the same organization as the library you just published.
Navigate to the Blocks panel
Open the Libraries tab
You will now see a My libraries section containing the blocks you published earlier
You may import the individual blocks or the entire library
Publishing a styles library
The same principle applies. A style library is a model containing a collection of styles that you can curate and open to other users.
Start from a model where you have styles you want to share.
Click on the
Share
Libraries
tab and togglePublish styles
on.
Navigate to the Styles panel
You will now see a My libraries section containing the styles you published earlier
You may import the individual styles or the entire library
We're always available!
Feel free to email us at support@rayon.so.
