> For the complete documentation index, see [llms.txt](https://docs.rayon.design/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.rayon.design/documentation/rayons-basics/signing-up.md).
# Signing up
Creating your Rayon account.
**Create a free Rayon account to start drawing.** Sign-up takes a few minutes: a form, a code sent to your email, a short survey and two preferences.
{% stepper %}
{% step %}
### Head to the signup page
To create a new account, <a href="https://www.rayon.design/app/auth/signup" class="button secondary">Sign up here</a>
{% endstep %}
{% step %}
### Enter your information <a href="#h_75510a44f2" id="h_75510a44f2"></a>
Type your name, your email address and a password in the **`Name`**, **`Email`** and **`Password`** fields, then press **`Create free account`**. You can also press **`Continue with Google`** to sign up with your Google account. If you are a student, use the **`Sign up as student`** link.
Rayon sends a confirmation code to your email address. Type it on the **`Verify your email`** screen and press **`Verify`**. If the email doesn't arrive, check your spam folder or ask for a new code.
<figure><img src="https://2112124689-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FngVHKyaUSSJPTFck3wkz%2Fuploads%2FawgbRSUckNULV8cdXC3B%2Fv4p-signup-p1-form.png?alt=media" alt="The Rayon sign-up page. The form reads Create a free account, with Name, Email and Password fields, a Create free account button, a Continue with Google button and links to sign up as a student or sign in. A collage of Rayon images fills the right half."><figcaption></figcaption></figure>
{% endstep %}
{% step %}
### Just a few questions <a href="#h_df1f293b51" id="h_df1f293b51"></a>
Rayon asks a few questions about you and your work. Choosing an answer takes you to the next one; for questions where you can tick several answers, press **`Continue`**.
If someone from a team has already invited your email address, Rayon then shows **`Join your teammates`**. Press **`Join`** to enter that team, or **`Skip this for now`** to continue on your own.
<figure><img src="https://2112124689-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FngVHKyaUSSJPTFck3wkz%2Fuploads%2FhJPGxO7m52qrx3LPWL4K%2Fv4p-signup-p2-survey.png?alt=media" alt="The first question after sign-up, What best describes you?, with ten answers such as Architect, Interior architect/designer and Student or faculty."><figcaption></figcaption></figure>
{% endstep %}
{% step %}
### Set up your preferences
Under **`Choose how to navigate the canvas`**, pick the way you move around a model:
* **`With a mouse`**: scroll to zoom, hold the mouse wheel pressed to pan.
* **`With a trackpad`**: pinch to zoom, pan with two fingers.
You can change both settings later in **`Preferences`**.
<figure><img src="https://2112124689-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FngVHKyaUSSJPTFck3wkz%2Fuploads%2Fvabk53oljP5OHNtuWd6u%2Fv4p-signup-p3-navigation.png?alt=media" alt="The screen Choose how to navigate the canvas, with two choices: With a mouse and With a trackpad."><figcaption></figcaption></figure>
Then, under **`Choose how to access commands`**, pick how you run commands:
* **`Using the command line`**: search commands as you type.
* **`Using shortcuts`**: trigger commands with hotkeys.
<figure><img src="https://2112124689-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FngVHKyaUSSJPTFck3wkz%2Fuploads%2FJTvDIHIRkURBFPMP65ca%2Fv4p-signup-p4-commands.png?alt=media" alt="The screen Choose how to access commands, with two choices: Using the command line and Using shortcuts."><figcaption></figcaption></figure>
{% endstep %}
{% step %}
### Explore the Quick start model
Your account is ready and Rayon opens a **Quick start** model. Its pages show you how to move around in 2D and 3D, draw a room, get help from AI and find your way around a model.
<figure><img src="https://2112124689-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FngVHKyaUSSJPTFck3wkz%2Fuploads%2FhZm1vMPJzcx1TL4q4bKF%2Fv4p-signup-p5-quick-start.png?alt=media" alt="The Quick start model open in the editor and centred, with four pages: Move around in 2D and 3D, Draw a room, Let AI help and Model overview."><figcaption></figcaption></figure>
{% endstep %}
{% step %}
### Go back home
When you are done, head back to the project manager. Open the main menu with the burger button at the upper left and press **`Back to models`**.
<figure><img src="https://2112124689-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FngVHKyaUSSJPTFck3wkz%2Fuploads%2FgCLmYrg2vkYRcHKug6Cy%2Fv4d-signup-7-back-to-models.png?alt=media" alt="The main menu opened from the burger button at the top left of the editor. The first entry, Back to models, is labeled; below it are Create new model, Duplicate model, Show history, Import, Export, Edit, View and Preferences."><figcaption></figcaption></figure>
{% endstep %}
{% step %}
### Alone or in a team? <a href="#h_9b5c24fd05" id="h_9b5c24fd05"></a>
You start in your own personal space, which is just for you. To work with others, add a team: open the space switcher at the top of the sidebar and press **`Add team`**. Type a name, choose **`How big is your team?`** and **`What is your company's sector?`**, then press **`Create team`**.
<figure><img src="https://2112124689-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FngVHKyaUSSJPTFck3wkz%2Fuploads%2FCXMEbD5jgFAGOfvjTZI6%2Fv4d-signup-3-new-team.png?alt=media" alt="The New team window over the project manager, with a Name field filled in, a logo placeholder, a How big is your team? list set to 1 - 5, a sector list set to Architecture and a Create team button."><figcaption></figcaption></figure>
To bring colleagues in, open a workspace, press **`Invite user`**, type their email address and choose a role:
* **`Admin`**: can edit models, change the team settings and manage the people in the team. Uses a seat.
* **`Editor`**: can see and edit the files of the team. Uses a seat.
* **`Viewer`**: can see the files of the team. Never uses a seat.
More about roles and seats on the [Teams](https://docs.rayon.design/documentation/team-management-and-pricing/teams.md) page.
<figure><img src="https://2112124689-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FngVHKyaUSSJPTFck3wkz%2Fuploads%2F8qY3qDxfm73oEyKk7QOF%2Fv4d-signup-4-invite-roles.png?alt=media" alt="The Access window of a workspace, with an email field, a role list open on Admin, Editor and Viewer, and an Invite button."><figcaption></figcaption></figure>
{% endstep %}
{% step %}
### Next step
You are done. Head to the next step.
<a href="https://docs.rayon.design/documentation/rayons-basics/your-workspaces.md" class="button primary">Next step</a>
{% endstep %}
{% endstepper %}
