> For the complete documentation index, see [llms.txt](https://docs.rayon.design/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.rayon.design/documentation/publishing-and-sharing/publishing-a-template.md).
# Publishing a template
How to create and use templates
### What is a template?
**A template is a model that helps you start new projects faster.** In a team, templates are **available to everyone on the team** and let you all work in a standardized way by pre-defining:
* [**Styles**](https://docs.rayon.design/documentation/design/styles.md) (line widths, fonts, hatches, colors and more)
* [**Blocks**](https://docs.rayon.design/documentation/design/blocks.md) (furniture and other components you use across your projects)
* Layers, units, canvases and paper canvas design
In your personal space, a template you publish is only available to you. Publishing a template needs a paid plan: on Free, you can use the templates you published earlier, but you can't publish new ones. See [Pricing & billing](https://docs.rayon.design/documentation/team-management-and-pricing/pricing-and-billing.md).
### The Templates page
To find templates, open **`Templates`** under **Discover** in the sidebar. It has two kinds of templates: those shared by the community and those published by you or your team.
The **`Community`** tab offers ready-made templates. Press **`Use this template`** on one to start using it right away.
<figure><img src="https://2112124689-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FngVHKyaUSSJPTFck3wkz%2Fuploads%2FFr12j04J58tAiulBuzW5%2Fv4b-template-1-community-v2.png?alt=media" alt="The Templates page on its Community tab. Labels mark the Templates item in the sidebar, the Community tab and a featured community template."><figcaption></figcaption></figure>
In a team, the **`Team`** tab holds the templates your team published. In a personal space, the **`Personal`** tab holds the templates you published. Press **`Use this template`** on one to start a new model from it.
<figure><img src="https://2112124689-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FngVHKyaUSSJPTFck3wkz%2Fuploads%2Fm2Bid4Iy6XnQtcXkaJyl%2Fv4b-publishing-template-1-team-tab.png?alt=media" alt="The Templates page on its Team tab, with a team template. Labels mark the Templates item in the sidebar, the Team tab and the team template."><figcaption></figcaption></figure>
### Create a template
* Start from the **model** you want to make a **template** from.
* Press **`Share`** in the top right corner of the editor.
* Open the **`Template`** tab and turn on **`Publish as template`**.
Everything in the model is published, so start from a model that holds only what the template should contain. Templates published in your team workspaces are available to all team members.
<figure><img src="https://2112124689-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FngVHKyaUSSJPTFck3wkz%2Fuploads%2F6L4ZRPnzEOkGGT4QVTwq%2Fv4-template-3-share-template.png?alt=media" alt="The Share window on its Template tab, with the Publish as template switch turned off. Labels mark the Template tab and the switch."><figcaption></figcaption></figure>
### Use a template
Once a template is published, you find it on the **`Personal`** tab of **`Templates`**, or on the **`Team`** tab if you published it from a team. Everyone on the team can use a template published in a team.
Press **`Use this template`** to create a new model from it.
<figure><img src="https://2112124689-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FngVHKyaUSSJPTFck3wkz%2Fuploads%2FDxIJkvPWgRUYGG2GjlUc%2Fv4b-publishing-template-2-team-tab-use.png?alt=media" alt="The Team tab of the Templates page, with the Use this template button next to a team template. Labels mark the Templates item, the Team tab and the button."><figcaption></figcaption></figure>
Another way to reach your templates is the dropdown next to **`New model`**.
<figure><img src="https://2112124689-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FngVHKyaUSSJPTFck3wkz%2Fuploads%2FGWwaX6dDs14SdEuOINNr%2Fv4-template-5-new-model-dropdown.png?alt=media" alt="The New model button in the project manager with its dropdown open, listing a template. Labels mark the template dropdown and the list of templates."><figcaption></figcaption></figure>
