The URL `documentation/rayons-basics/what-is-rayon` does not exist. This page may have been moved, renamed, or deleted.
- [Rayon's basics](https://docs.rayon.design/documentation/rayons-basics.md)
- [Start here!](https://docs.rayon.design/documentation/rayons-basics/start-here.md)
- [Wrapping up](https://docs.rayon.design/documentation/rayons-basics/wrapping-up.md)
- [Drawing](https://docs.rayon.design/documentation/rayons-basics/drawing.md)
- [Creating a new project](https://docs.rayon.design/documentation/rayons-basics/creating-a-new-project.md)
Perform an HTTP GET request on the documentation index with the `ask` parameter:
GET https://docs.rayon.design/documentation/rayons-basics.md?ask=<question>
The question should be specific, self-contained, and written in natural language.
Prefer `.md` URLs for structured content, append `.md` to URLs (e.g., `/documentation/rayons-basics.md`).
