> For the complete documentation index, see [llms.txt](https://docs.rayon.design/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.rayon.design/documentation/rayons-basics/creating-a-new-project.md).
# Creating a new project
Create a model from scratch
This page takes you step by step through **your first steps in the editor.**
{% stepper %}
{% step %}
### Creating a model <a href="#h_064b5664d5" id="h_064b5664d5"></a>
To start a new project, you can:
* Create a new model from scratch
* Import a DWG/DXF, a PDF, an SVG or an image ([more on this topic](https://docs.rayon.design/documentation/import-export.md))
* Start from a template, with the dropdown next to **`New model`** ([more on templates](https://docs.rayon.design/documentation/publishing-and-sharing/publishing-a-template.md))
Start with a new model from scratch: press **`New model`**. Rayon **creates a new drawing in your workspace and opens it.**
<figure><img src="https://2112124689-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FngVHKyaUSSJPTFck3wkz%2Fuploads%2F14LtLpnsk0L4MF78IABt%2Fv4b-creating-1-new-model-v2.png?alt=media" alt="The top of the project manager, with the New model button on the right, labeled New model."><figcaption></figcaption></figure>
{% endstep %}
{% step %}
### The model canvas <a href="#h_24f5548ecb" id="h_24f5548ecb"></a>
You arrive in the model canvas, **the space where you draw.** Here are the areas around the canvas.
<figure><img src="https://2112124689-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FngVHKyaUSSJPTFck3wkz%2Fuploads%2FZsUY6UVNjbSNfQNniht5%2Fv4b-creating-2-new-model-empty-editor.png?alt=media" alt="A new, empty model open in the editor: the left rail of panel icons and the AI panel, the empty canvas with the toolbar at the bottom, and the Properties panel on the right."><figcaption></figcaption></figure>
{% endstep %}
{% step %}
### **The left-side panels**
On the left, a rail of icons opens the **main panels**:
* The main menu, to go back to your models, create or duplicate a model, show its history, import, export and set your **`Preferences`**
* The [layers](https://docs.rayon.design/documentation/design/layers.md) panel
* The [pages](https://docs.rayon.design/documentation/layout-and-present/pages.md) panel
* The [blocks](https://docs.rayon.design/documentation/design/blocks.md) panel
* The [styles](https://docs.rayon.design/documentation/design/styles.md) panel
* The [tables](https://docs.rayon.design/documentation/layout-and-present/tables.md) panel
* The [properties](https://docs.rayon.design/documentation/layout-and-present/custom-properties.md) panel
* The [comments](https://docs.rayon.design/documentation/rayons-basics/sharing-commenting-annotating.md) panel
* The [AI](https://docs.rayon.design/documentation/work-with-ai.md) panel
<figure><img src="https://2112124689-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FngVHKyaUSSJPTFck3wkz%2Fuploads%2F5mbb2nSsYGNnWpWZSgG0%2Fv4-creating-3-left-rail.png?alt=media" alt="The left rail of the editor, with the Layers panel open. Labels mark the icons for the menu, Layers, Pages, Blocks, Styles, Tables, Properties, Comments and AI."><figcaption></figcaption></figure>
At the bottom of the rail you find the **`Notifications`** bell, the appearance switch, and the learning, shortcuts and help buttons.
{% endstep %}
{% step %}
### The properties panel
On the right side is the properties panel. At its top you find the model's:
* **Avatars** of the people in the model
* **Status** and **model history**
* **`Share`** button, to invite people, publish a template or present ([more on sharing](https://docs.rayon.design/documentation/publishing-and-sharing/sharing-a-model-or-a-workspace.md))
To show your pages on screen or send them to your client as a **presentation**, open the pages panel on the left ([more on this topic](https://docs.rayon.design/documentation/layout-and-present/presenting-your-project.md)).
<figure><img src="https://2112124689-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FngVHKyaUSSJPTFck3wkz%2Fuploads%2FC33G3ENJczTqV62zv5ea%2Fv4-creating-4-top-of-properties.png?alt=media" alt="The top of the Properties panel, with labels on the avatar, the status and model history button, and the Share button."><figcaption></figcaption></figure>
The panel is divided into sections:
* **`Model`** holds the **`Name`** and the **`Owner`** of the model.
* **`Model canvas`** holds the settings of the canvas you are in: **`Name`**, **`Active layer`**, **`Display`** (**`Default`** or **`Wireframe`**), **`Grid`**, **`View borders`**, **`Stroke scale`**, **`Background`** and **`Unit`**.
* **`Custom properties`** holds the properties you add to your model.
* Other sections describe the properties of your current selection.
<figure><img src="https://2112124689-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FngVHKyaUSSJPTFck3wkz%2Fuploads%2F2xdX11XN9UUIwRezPVlk%2Fv4-creating-5-model-and-canvas.png?alt=media" alt="The Properties panel with the Model section, labeled Model settings, and the Model canvas section, labeled Model canvas settings."><figcaption></figcaption></figure>
In the bottom right corner, you find:
* **The snapping options**, which define how your cursor snaps onto geometry when you draw.
* **The zoom level and units dropdown**, to set the model's units and the zoom level of the current view.
<figure><img src="https://2112124689-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FngVHKyaUSSJPTFck3wkz%2Fuploads%2FTirA2rhiXVuZG1IBvESb%2Fv4-creating-6-bottom-right.png?alt=media" alt="The bottom right corner of the editor, with the snapping button labeled Snapping options and the zoom scale labeled Zoom level and units."><figcaption></figcaption></figure>
{% endstep %}
{% step %}
### The toolbar
The toolbar at the bottom holds the **select and search tools**, then these groups:
* **The** **`Elements`** **tools**: all the basic geometries.
* **The** **`Shapes`** **tools**: all constructive objects.
* **The** **`Annotations`** **tools**: text, dimensions, leaders and more.
* **The** **`Editing`** **tools**: for editing existing geometries, as in any professional CAD software.
* **The** **`AI tools`**: tools that use AI credits ([more on AI credits](https://docs.rayon.design/documentation/work-with-ai/ai-credits.md)).
* **The** **`Layout`** **tools**: for creating layouts (views, pages, tables).
* **The** **`Utilities`** **tools**: for commenting, doodling or measuring.
<figure><img src="https://2112124689-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FngVHKyaUSSJPTFck3wkz%2Fuploads%2FUqC78ZmlIPcFRVC3V84S%2Fv4-creating-7-toolbar.png?alt=media" alt="The editor toolbar with a label under each tool group: Elements, Shapes, Annotations, Editing, AI tools, Layout and Utilities."><figcaption></figcaption></figure>
{% endstep %}
{% step %}
### Next step
You are done with the editor. Press the button below for the next step.
<a href="https://docs.rayon.design/documentation/rayons-basics/navigation-and-command-access.md" class="button primary">Next step</a>
{% endstep %}
{% endstepper %}
