Import & Scale a Floor Plan Image
Starting a project by drawing over an image of a floor plan is super common with Rayon 🖼️
To do so, simply follow the next steps:
Import
Your image (JPG or PNG) of a plan onto the canvas.
Use the
Scale (S)
command to rescale the image, given a distance of reference. If you don't have a distance of reference, you can always use an estimated size of a door (80~ cm), as we did in the GIF above.To make sure the plan was scaled, you can simply use the
Distance (DI)
tool from the bottom toolbar to measure the new dimension.
💡 Make sure to follow the instructions in the command bar at the bottom of the screen!
We're always available! 💬
-> Feel free to email us at support@rayon.so if you need more info 🙌
