Navigating In a Model
Moving around in a model🖱️
Navigation in Rayon is the easiest thing. It all depends on the device you are using, which you can customize from the main account preferences or from within a model, as you can see below:
I am using a mouse 🖱️
To Zoom, simply Scroll.
To Pan, hold your mouse wheel down and move.
To Select something, either click on it or capture it in a selection window by clicking and dragging it anywhere in your model. Clicking while holding
SHIFT
will either add or remove from the selection.
I am using a trackpad 👆
To Zoom, pinch on your trackpad or
CTRL
+ Scroll with a mouse.To Pan, use your trackpad (2 fingers on an Apple trackpad) or hold your mouse wheel down and move.
To Select something, either click on it or capture it in a selection window by clicking and dragging anywhere in your model. Clicking while holding
SHIFT
It’s as simple as that! 🎉
We're always available! 💬
-> Feel free to email us at support@rayon.so if you need more info 🙌
